Siemens oven won’t heat up Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Siemens oven won’t heat up This topic has 2 replies, 3 voices, and was last updated 8 years, 10 months ago by Dawn63. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts May 24, 2017 at 9:26 am #91311 Dawn63Participant Siemens oven won’t heat, first it blew the fuses, then when switched back on only fan works, even when oven is switched off fan still runs unless I turn it off at the wall. Only 2yr old and it shows error code E005 May 24, 2017 at 1:37 pm #447712 electrofixModerator Re: Siemens oven won’t heat up is it under or over 2 years old ? 2 year guarantee if no element is first thing to check also moved you post to the correct forum Dave May 24, 2017 at 1:41 pm #447713 MartinParticipant Re: Siemens oven won’t heat up Sounds like the fan element has also taken out the circuit board? Ouch! Expensive 🙁 Let’s hope this model carries a 5yr guarantee. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
