Siemens sd6p1s
  • #94745
    nivek1
    Hi Kevin here and new to this site,have the above dishwasher sn.66T097GB/93 and accidentally pulled the 3 grey (temp. control?) wires from the heater/pump unit,I can see where they go to on the main control board but need to know which order they go on the plug end.
    #458198
    you seem to have got the Enr number wrong
    not many people on here have access to Siemens tech info.
    I am assuming you are talking about the small 3 pin plug on the motor that connect to the temp senders on the motor. I have a similar Bosch machine and if I can find 5 mins tomorrow will try and see which leads go where. But , there are a number of board used on these machines, I know the motor plus has 3 wires but on your machine how many connections are on the plug connecting to the module ?
    nivek1
    Hi Dave and thanks for your quick response,there are 3 pins/connections on the plug and the other ends that connect to the main board are beside 3 yellow wires of similar size.
    I’m not sure what you mean about the Enr number,if its the serial no.that is the correct one I gave earlier.
    Regards Kevin
    #458200
    you say its Enr 66T097GB/93 but that’s not correct as it should come up in here
    https://www.siemens-home.bsh-group.com/uk/customer-service/support/search-parts
    will have a look at the one I have tomorrow and see if there are 3 wires on both ends
