Sometimes this dishwasher heats correctly then appears to only slightly heat(users term).
It sticks on one minute and also occasionaly heats the prewash water on auto setting.
Its quite normal for this machine to use the same water for the main wash from the pre-wash cycle. If the turbidity sensor senses that the pre-wash water is clear/not dirty, it will continue into the main wash without draining & refilling (to save water). It will however drain the water if the sensor senses cloudy/dirty water & refill with clean water. Leaving 1 minute in the display & sometimes not heating usually indicates that the left hand side water chamber & pressure switch assembly & or the sump hose is blocked with deposits. This causes a lack of water entering the sump causing cavitation in the circulation pump. This then stops the pressure switch on the heater activating due to a lack of wash pressure causing the intermittant heating problem. I would’nt invest in new modules until you are happy that the machine is filling correctly.
