Siemens SE24201GB/07
  • #41526
    clayside
    Having trouble with above. Does cycle ok but half fills overnight. It’s not fill valve or draining back from sink as I’ve changed valve and it drains into standpipe and I’ve checked non-return valve it only leaks so much dosn’t matter how long its left. When you unscrew salt cap quite a lot of water escapes into machine so think its pressure in water softener. Has anyone had this. Regards clayside
    #270480
    Re: Siemens SE24201GB/07
    Retained water in the matrix draining down? Check release solenoid below it.
    clayside
    Thanks Chris, Will call back and look.
    Regards clayisde
