I have a siemens dishwasher that will not complete it’s cycle, it runs for about 30 minutes and then sounds as if it is trying to pump the water out.
with the door open the pump continues to run and all of the water has been pumped out, reset the cycle and turn off for a few hours and it starts up and runs fine for a few cycles then stops mid cycle again and it is now occuring more frequently.
i have cheked the drain hose for blockages and stripped and cleaned the impellor and the inlet hose filters, any suggestions?
martin
