Re: Siemens SE24A230gb/17 FD8204
Been there… Done that… Got the blown up module in the van to prove it. 👿
It’s an expensive lesson to learn. Mine turned out to be the dispenser at fault but I was not going to risk another module so the machine got dumped in the end. 🙁
As Martin says, inspect the board for blown components. It’s a small surface mounted transistor/triac thingy that will look as if it’s chipped on one corner. If you follow the track from that component to an edge connector and then trace the wiring it will take you to the faulty component.
Bob
