Siemens SE24A230GB/17 Hydrosensor dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens SE24A230GB/17 Hydrosensor dishwasher
  • #50840
    Micky 32
    According to the FD number made in 2002. When you switch it on , even if the door is open, The drain pump activates and is filling at the same time constantly. Flood switch not activated. Also the small display all the segments are lit up. I’m guessing computer?
    #306113
    Re: Siemens SE24A230GB/17 Hydrosensor dishwasher
    Micky 32 wrote:I’m guessing computer?
    Good guess but I suspect something has caused the ‘control module’ to blow in the first place? Take it off and look closely at what (if any?) damage is on the board? Then trace the nearest plug in connectors adjacent to where the board has blown. Trace the wires to the guilty component.
    All the above information assumes that the flood switch hasn’t been activated of course. 😉
    #306114
    PINKY
    Agree with Martin. Your find a triac with a blown top if you look carefully. If your lucky it will be the dispenser otherwise it’s usually diverter motor on the heater box 😥
    #306115
    Micky 32
    Thanks for the reply lads, so it’s module related. Have to go back later and strip, didn’t have time earlier. Probably not worth fixing anyway? First thing i checked was the flood switch. It was ok.
    #306116
    Pigpen4
    PINKY wrote:Agree with Martin. Your find a triac with a blown top if you look carefully. If your lucky it will be the dispenser otherwise it’s usually diverter motor on the heater box 😥
    Has anyone had any joy replacing this triac?
    If so, is there a part number for it, or have you scavenged one from an old board?
    I’ve got one with a blown diverter valve triac!
    Pigpen.
