siemens se24a230gb/17 won’t reset
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemens se24a230gb/17 won’t reset
  • #37240
    cornwell40
    Customer complaint of no go , won’t reset display shows 188.
    Indeed all of the above, side switches test fine although the metering tank is a little cruddy. Anti flood not activated.
    Checked the board for obvious bangs but nothing showing.
    Power up and the display shows 188 with the pump running constantly.
    I’m suspecting a board fault but anyone have any other ideas on this.
    Its a scrap if expensive call so the board is already o.t.t :rolls:
    TC
    #254029
    gegsy
    Re: siemens se24a230gb/17 won’t reset
    Sounds like module fault IMO.
    cornwell40
    Just as a matter of interest, what should the motor readings be on this machine?
    TC
    #254031
    gegsy
    You have mail, may help 😉
    cornwell40
    Greg, you’re a Gent 😀
    TC
