Re: Siemens SE24T250GB/17 Problem
hi
I have seen this fault with a jammed circulation motor.
Drain pump works fine but there is not much circulation?
Remove the RHS of the machine and check the main motor is turning.
It will be a blur if the motor is running OK
If not PLEASE turn the power off and then you can move the motor vanes with your finger or suitable screwdriver etc
I have posted pics of the motor in my recent thread just below yours….
regards
