Siemens SE25530GB/12 D/W
  • #64431
    rocker
    called today no drain fault…removed side tank water level unit cleaned & fitted new pump…on start up pumps runs and fill with water and washes..the water heats but cycle won’t finish.
    also if the cancel buttons are pressed the cycle dosent finish and pump dosent run !!!
    I am presuming the module may be faulty !!! can anyone please confirm.
    thanks John
    #357078
    Re: Siemens SE25530GB/12 D/W
    If the machine won’t reset at any point in the cycle then it’s certain to be the module at fault. 🙁
    #357079
    rocker
    Thanks Martin, Thought as much so thanks for comfirming.
    before I tell the customer. John
