Been looking through some posts about Bosch DW’s and the impeller jug is mentioned as the fault similar to the Siemens. ( water check )
Would it be the same part by any chance and how the hell do you get the sides and back off ?
It depends Will, not knowing the exact symptoms in your case OR the full model number? You don’t want to fix something if it ain’t broke after all do you? Your obvious frustration at getting inside will perhaps cause further grief too. But take the lid off first then the left hand panel comes away having removed just 2 screws down the front. Accessing the Impellor jug continues with the removal of the rear inlet valve plate. Have fun! 😀
Dishwasher just sits with water check light on, or it gets through a program, say 118 minutes and stops on 31, water check error. Very intermittent. Can’t see a model number as such, other than Type S9G1S, (stainless steel front, square switches).
Works sometimes if I pull it out from under the worksurface !
Well guys, I removed the top and side panels, saw the impeller jug and nearly put the panels back on !
Fortunately, replacing it was easy and it has fixed the problem.
Thanks very much. ( got fed up washing up )
