Siemens SE25M851GB water light
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens SE25M851GB water light
  • #81606
    pw453
    Hi all
    Seen a couple of posts on this topic, but want some advice
    Had the machine 6 years and used daily.
    Last night put on normal cycle and found later that it was stuck emptying the water, with red light on.
    This morning checked the drain area and it was empty.
    Filled with water and reset machine and tried a short wash.
    Drained the excess water, but just kept doing that and red light for “check water” came on.
    Ideas or solutions?
    Paul
    “If you wake up thinking today will be a good day, then it will”
    8)
    #417149
    Re: Siemens SE25M851GB water light
    Water in the base tray caused by internal leak somewhere I expect.
    #417150
    pw453
    Thanks I will take the panels off and have a look.
    I will let you know how I get on.
    Paul 🙂
    #417151
    pw453
    Got panels off, and yes water in the bottom tray.
    now trying to spot how the water got there….
    Any ideas?
    #417152
    Overflow from fill matrix/pressure chamber?
    Leaking main pump shaft seal?
    Loose salt container collar?
    Leaking water heater diverter mechanism?
    For possible starters…… 😉
    #417153
    pw453
    Found that their is a pipe on the right side of the machine as you look at it, that connects to the middle of the machine.
    This pipe goes to the back and under the machine and connects to fresh air….
    All around this pipe area has water muck…
    Cant get to anything where this pipe goes as to much electrics and motors…
    #417154
    pw453
    https://www.dropbox.com/s/x50j5huhw57nq … .23.24.jpg
    #417155
    It’s just the steam expansion pipe. It is not attached to anything and easily pulls out from its location should you choose to do so.
    #417156
    pw453
    It seems I have a lot of water muck to the right side of the machine.
    I am also at a loss of how to get to the pipes and seals you talk of, i expect i will need someone who knows what they are doing.
    Thanks for your help, but think i will end up washing up by hand and same money to buy a new machine…
    #417157
    That’s a same. It’s a quality machine and a local independent repairer could sort it I’m sure 💡
    #417158
    pw453
    I will try that thanks
