Siemens SE26A260GB/13 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens SE26A260GB/13 Dishwasher
  • #65846
    Latham63
    Initial fault,not draining.Removed obstacle from pump.Ok.
    Now sticks on a wash cycle with display on 1min?
    When door opened always has suds as if rinse has not happened.Drains ok.
    does the continuous 1 min dispay suggest an aborted prog?
    Or perhaps a blockage elsewhere?
    #362108
    Re: Siemens SE26A260GB/13 Dishwasher
    Latham63 wrote:does the continuous 1 min dispay suggest an aborted prog?
    It indicates a programme ‘time-out’ at some point during the cycle.
    Latham63 wrote:Or perhaps a blockage elsewhere?
    Very likely, you’ll need to remove and clean the pressure chamber and sump transfer pipe I expect. Also take off the right hand side panel and check (megger) the heater while you’re there. 😉
