siemens se26t251gb won’t start….
Home Forums Public Support Forums Help And Support Dishwasher Help Forum siemens se26t251gb won’t start….
  • #77468
    rogtug
    I am happy to do bits to repair my dishwasher when required – normally cleaning the inner inlet pipe etc.
    But last week the heater failed.
    Yesterday I replaced it and put it on a wash to test it. Dishwasher and heater worked fine but there was obviously a slight leak from somewhere. So this morning I opened it up again and checked all the pipe junctions. One looked dodgy – I had got the washer wrong. Sorted that and put it back together. BUT now it won’t turn on….
    The display shows 93 which will be the minutes of the program. There is a buzzing coming from one of the inlet valves which is obviously activated. But nothing else happens.
    By accident I managed to put it into a test cycle – by pressing the Reset buttons at the same time as the On switch. It has run through this cycle fully twice now. Lots of bleeping and flashing on the way both times. The wash seems to progress perfectly and the heater is definitely working. At the end it only displays ‘0’, not any error codes.
    Turn it off and on again and I’m back to square one….
    HELP !
    #402276
    Re: siemens se26t251gb won’t start….
    It’s impossible to imagine what has happened to your machine during dismantling and reassembly. Broken wire? Leaked water onto connector block? Shorted connection somewhere? Nothing you tell us is symptomatic of any known faults I’m afraid. You’ve just got to hope you have’nt buggered up the main PCB…… eeek!
