Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Siemens SE34A260SK/47 wont heat water, stuck on 1 min
- This topic has 8 replies, 2 voices, and was last updated 13 years, 1 month ago by
juspe.
March 25, 2013 at 10:24 am #74726
juspe
ParticipantHi, my Siemens SE34A260SK/47 stopped heating water. Also when using auto program it gets stuck to 1 min. I think the heating element need to be replaced. Do you think thats the solution?
Is the Bosch part number 488856 right heating element for my machine? I have not yet taken it apart.
http://www.ebay.com/itm/GENUINE-BOSCH-D … 565330b60b
Thanks!
March 25, 2013 at 11:06 am #392660Martin
ParticipantRe: Siemens SE34A260SK/47 wont heat water, stuck on 1 min
juspe wrote:Do you think thats the solution?
Could be but needs testing first with a meter to be sure? Also the main PCB may be at fault (burnt heater relay terminal?)
juspe wrote:Is the Bosch part number 488856 right heating element for my machine? I have not yet taken it apart.
Yes it is and you’ll have such fun doing it! 😀
March 25, 2013 at 1:22 pm #392661juspe
Hi and thanks for your reply!
I started to take is apart and it was quite hard. This is my first time repairing dishwasher :rolls:
It looks now like this:
https://www.dropbox.com/s/fsnyf3d9pj3s4 … 151802.jpg
https://www.dropbox.com/s/s99sughiyvr9e … .09.52.jpg
https://www.dropbox.com/s/orce95r69e7vb … .09.58.jpgCan i test it there or do i need to take it apart more? How do i test it? Resistance with multimeter? Between which two points?
Thanks.
March 25, 2013 at 1:41 pm #392662Martin
juspe wrote:How do i test it? Resistance with multimeter? Between which two points?.
Remove the red wire and the wire/green wire from the heater terminals to get resistance readings.
Did I spot mouse droppings in the plastic base?
March 25, 2013 at 3:37 pm #392663juspe
Martin wrote:Remove the red wire and the wire/green wire from the heater terminals to get resistance readings.
23-24ohm. So its should be working?
Martin wrote:Did I spot mouse droppings in the plastic base?
Yes, there was mouse nest behind the dishwasher and it was cleaned + the mouse trapped couple of months ago.
What is the next thing to test?March 25, 2013 at 3:41 pm #392664Martin
juspe wrote:What is the next thing to test?
See my first reply to you regarding the PCB and check that ruddy mouse hasn’t chewed through a heater wire…..!
March 25, 2013 at 6:02 pm #392665juspe
Ok, I checked what i think was that PCB. And there you can see some burn damage.
Photos:
https://www.dropbox.com/s/mqupvt4xyrqa0 … .47.56.jpg
https://www.dropbox.com/s/ihjk1f1zcpj86 … .48.06.jpgAnd the mouse had chewed 2 wires insulation. One i fixed with tape and other i soldered 5cm of new wire.
What do you think had caused that burn on card?
EDIT: Is it just that relay that have failed? Is it possible to get it working by just soldering new relay there?
March 25, 2013 at 6:44 pm #392666Martin
juspe wrote:Is it just that relay that have failed? Is it possible to get it working by just soldering new relay there?
It certainly is possible yes though the burnt area on the component side looks a little more severe than usual. Give it a go anyway!
April 12, 2013 at 12:24 pm #392667juspe
I finally got new relay (my local electronic shop had to order it and it took 2 weeks..) and desoldered the old one.
The burnt area looks kinda bad:
https://www.dropbox.com/s/z2hyhj0xg0hvr … 145420.jpg
And the new relay got 5 legs and the old one only 4. Can it still be used?
https://www.dropbox.com/s/vu2hacf5a6su3 … 150926.jpg -
