ive removed blockage from pump impellor but the display is flashing a no1 and the normal wash light is flashing (the second one from left) if i turn it off at the mains the drying indicator comes on but when the on/ off switch is turned off & on it goes back to the above, no other buttons will operate i guess there must be some way to reset it? any ideas?
Press and hold in the first and third programme buttons for 3 secs whilst the machine is on will clear any error. If it doesn’t then the module is faulty!
one of the lugs on the module case had broken so the third button wouldnt connect does anyone know if i can get the case on its own or do i have to buy the complete module?
