Siemens SE64630GB/17
  • #40096
    Skips
    Can anyone suggest a solution? The Siemens Dishwasher i have seems to be stuck! it completed a full wash cycle but the pump stays on continually. i have tried to reset it but it is still the same. Symptoms are if you open the machine and push the power button, the motor at the base of the washer spins continuously. are the pipes blocked? no water is coming through the washer arms although i presume this would only happen if the door was closed? any help is appreciated. Thanks
    #264751
    Re: Siemens SE64630GB/17
    Flood protection operating will run the drain pump continuously. Check for water in the undertray.
    Skips
    I cleared the water and cleaned some of the pipes inside the machine on the left hand side. after much turning on and off it has now started working. Many Thanks for your reply!
    #264753
    Skips wrote:Posted problem with dishwasher earlier and thought it was fixed. appears that the problem must relate to it not draining properly. opened up the machine and it looks fairly clean. affter clearing all the water out before, it worked and ran through a full cycle but when i opened the machine it is full of water. i tried to manually activate the microswitch on the left hand side which activates the pump. it start the motor and the small wheel spins inside the machine but it does not drain. am i right in assuming he drain pipe is the one leaving the resevoir at the front of the machine underneath? and is this likely to be clogged with something or will it be the motor? thanks in advance!!
    Keep it in one thread, Skips – chaos normally ensues……….
    Penguin45,
    Moderator.
    #264754
    Remove left hand side panel and observe what is happening in the back half of the water matrix. You say the drain pump runs, so water should be pumped through the rear two tubes when emptying. Machine will not pump with the sump cover off, btw.
    Skips
    All working now! complete 2 full washes and no problems. Thanks again
