Siemens SE65T370GB/02
  • #43950
    rocker
    Tested this dishwasher fills with water -heats -washes- rinses- drains- then when going into drying cycle (no heat) machine dosen’t finish cycle, always 1minute left on timer.
    I guess it could be timer, or can anyone please advise.
    Thanks John.
    #279201
    Re: Siemens SE65T370GB/02
    Like all BSH dishwasher of this type it’s usually due to gunged up pressure chamber or transfer pipe. If you use SEARCH on STUCK AND 1 AND MINUTE you’ll see what I mean. 😉
    #279202
    rocker
    Cheers Martin, I didn’t check these parts , as I explained all appeared to be working ok so dismissed, but will recall and check.
    Cheers john.
    #279203
    rocker
    Martin. spot on. I removed and cleaned side tank and transfer pipe some slight gung found. works fine now.
    cheers john.
