Looking for a bit of help and advice.
The dishwasher is around 6 years old and following some unusual noises on it’s last wash the machine did not empty the water.
There are no blockages of the filters or the waste pipe so I bought a new Waste pump (Pt No. 483054) with a view to fitting it. I have dismantled the machine to the stage that I can see the waste pump under the L/h sidepanel (if looking at from the machines door).
But, without removing a lot of stuff from the machine and perhaps ‘lifting’ the main body off the base is there a way to change the pump?
Assuming I have to remove a lot of bits from the machine are there any on line guides or handy advice before I have a go?
thanks Jez
