Siemens SF24T553GB/18 Dishwasher Prob’/s
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens SF24T553GB/18 Dishwasher Prob’/s
  • #91914
    jontymox
    Good afternoon all,
    Wondering if anyone can help with an obscure fault on the above dishwasher?
    The unit drains, fills, and then “pulses” through the water circuit. (matrix, pressure chamber) and also seems to gurgle through the drain circuit, during which time the wash pump doesn’t operate.
    The matrix and pressure chamber are nice and clear, and not blocked, and I suspect the flow meter (impeller jug) but would welcome some assistance.
    Kind regards,
    jonty
    #449685
    jontymox
    Re: Siemens SF24T553GB/18 Dishwasher Prob’/s
    p.s.
    The problem is accompanied by the tap light being illuminated.
    I’ve checked and cleaned the drain pump/impeller, and the water hoses aren’t kinked.
    #449686
    jontymox
    Well, I’ve renewed the flow sensor and after a strange filling operation, (filling together with draining, until settled) the wash pump activated, and a wash cycle was completed.
    However, the machine still isn’t happy and during the above quick wash, the above fill problems were repeated.
    It appears to remain a fill problem, and the water tap light illuminates at random, although usually remains off.
    Any help much appreciated.
    jonty
    #449687
    Yep, impeller jug (00607138) needs replacing.
    #449688
    jontymox
    Good evening Martin,
    I’ve replaced the flow senor/impeller jug, but the symptoms remain.
    Have re-checked the connections, which are fine so still struggling….
    #449689
    I’m struggling also as to what could be causing it. The gurgling you mentioned earlier suggests a blockage but you say all hoses are clear.( I guess that includes the sump hose?).
    What else is left? Aquastop? Impeller Jug connections on the control unit? Or maybe something stupid like the customer has put detergent in the salt reservoir and now it’s blocked the ion exchange unit?
    Just guessing 😕
    #449690
    jontymox
    Wondering if someone has a wiring diagram for this model, which they could send?
