Siemens SF64M330GB/15 integrated slimline dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens SF64M330GB/15 integrated slimline dishwasher
  • #51132
    paulus22
    Just before Christmas and this breaks down!! The drain pump has given up and I have now got its replacement. I have removed the machine from its housing, and expected to access the pump from the bottom – but the bottom seems an integrated plastic assembly. How do I get into the machine to access the drain pump??
    Wife giving me jip – any help is much appreciated.
    paulus22
    #307030
    Re: Siemens SF64M330GB/15 integrated slimline dishwasher
    Remove plug, door outer, lower cover panel. Pump is a twist-fit in the front left. Pull the transfer pipe out for better access.
    paulus22
    Penguin45 – thanks for quick reply, but please help me to understand better.
    Are you saying that this can be done with the machine in situ? And are the instructions:
    1. to remove the plug (obvious)
    2. remove just the kitchen front on the door, or the complete door (how?)
    3. lower cover panel (I can see a metal cover panel with a cable loom clipped on its inside – is this it? or are you refering to the white plastic base, in which case how?)
    Thanks in anticipation for this clarification
    paulus22
    #307032
    paulus22
    Making progress. Door off, panel off, can access the pump BUT it is not firmly located anywhere. The outlet is at the back – does it just need brute force, or is ther a technique for freeing the hose? The inlet is a rubber connection , which if I got off I wouldn’t know how to reconnect – since it is largely inside of a plastic shroud (maybe it pulls out then pushes back in again?). The pump itself just floats between these two connections.
    Please give me little guidance here.
    Finally, should I get that far, what is required to ensure good seeling of the new connections?
    Thanks again,
    paulus22
    #307033
    paulus22
    Sorted! The replacement pump came assembled with the inlet/outlet chambers. Didn’t realise that I could seperate and swap just the pump onto the existing chambers – no connections to worry about.
    Job’s a good’n. Thanks again.
    #307034
    paulus22
    Spoke too soon!
    Put it all back after changing the drain pump – and its still not emptying!
    Before changing the pump I had checked all of the basics:- filter, kink in pipe etc. and hence concluded it must be the pump – but it obviously is not. Any ideas where to next?
    paulus22
