Siemens Siwamat 5100 Not Heating Water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens Siwamat 5100 Not Heating Water
  • #46277
    Stompa
    I suspect my Siemens Siwamat 5100 is not heating the water.
    E-NR: WM51000GB/01
    FD: 7605 00086
    It completes wash cycles as normal, however the glass door of the washing machine is not getting warm.
    I’ve tried running an empty 90°C cycle, and still the door is not warm. After stopping it mid-wash and pumping out the water, the sides of the drum are not warm. If I stick my finger under the water flowing into the soap dispenser, that’s not warm either.
    Any ideas?
    Stompa
    #288785
    Re: Siemens Siwamat 5100 Not Heating Water
    Plug out, back off, resistance check with your test meter should show 20-25 ohms through the heater when split from the circuit.
    Stompa
    Penguin45 wrote:Plug out, back off, resistance check with your test meter should show 20-25 ohms through the heater when split from the circuit.
    OK, thanks.
