The problem started last week when we were getting error code 3. I checked the sump pump by removing the cover and cleaned it out. It still came up with code 3 so I removed the hose from the sump pump to the vessel at the back along with the drain hose and cleaned them all out. (Unbelievable gunge inside). Now it washes but stops at the rinse cycle with code 2. If we stop it and then start at spin it continues ok and drains ok.
Only codes 1, 3 and 8 are in the booklet.
Any idea what it could be and what error code 2 is?
Error code 2 is a heating fault.
If you going to check heater (app 30 ohms) always pull the plug :plug:
Also with the age of appliance its not uncommon to have the empty pump intermittently jamming causing error 3 :plug: again.
