Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens Siwamat 6140: Error code 4
- This topic has 8 replies, 3 voices, and was last updated 20 years, 5 months ago by
Aja.
November 12, 2005 at 12:49 pm #13242
Aja
ParticipantMy washingamshine stops before compleating the program, blinking the lamp “cloth-softening” and error code 4. Restarted the mashine and this time it completed the program. Next run, the same happened. Any ideas what this error message is about. Its not mentioned in the manual (only 1,3 and 8 ). Thanks in advance.
November 12, 2005 at 2:25 pm #153739gegsy
ParticipantRe: Siemens Siwamat 6140: Error code 4
will need full enr/fnr numbers off machine pleaseGreg
November 12, 2005 at 2:36 pm #153740Aja
E-NR WM61400SN/01 FD 7609 01012
Hope this will help
November 12, 2005 at 3:02 pm #153741gegsy
Error code 4 and conditioner lamp flashing is a fault with the motor no turning properly.
November 12, 2005 at 4:24 pm #153742Aja
Thanks.
Observed the washer at the next run, and found that the motor din not run at all. I’m hearing the relay switches on and off, but no action on the motor. I will now open the washer and try to fins out what causing this.
November 12, 2005 at 6:38 pm #153743gegsy
Aja wrote:Thanks.
With the appliance unplugged :plug: of course 😉
November 13, 2005 at 11:11 pm #153744Aja
Found the the brushes was worn down to almost nothing. The inside of the washer was cover with carbon dust. Maybe the commutator should be shaped up before replacing the brushes. One of the brush wires had come trough and made a track in the commutator.
November 13, 2005 at 11:44 pm #153745gegsy
Aja wrote:Found the the brushes was worn down to almost nothing. The inside of the washer was cover with carbon dust. Maybe the commutator should be shaped up before replacing the brushes. One of the brush wires had come trough and made a track in the commutator.
I would say that commutator has been permanently damaged.
When you replace the brushes, you may get a lot of sparks.If this is the case a replacement motor is only cure.
You may get lucky and all may be fine. Clean com up with a comstick before introducing new brushes.Power off first of course :plug:
November 14, 2005 at 1:09 am #153746Penguin45
An email to spares@ukwhitegoods.co.uk will magically produce the brushes for you.
Penguin45. -
