Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Siemens Siwamat WXB860BY/05
- This topic has 9 replies, 4 voices, and was last updated 19 years, 3 months ago by
Dragan.
December 14, 2006 at 6:11 pm #23378
Dragan
ParticipantHi,
this washer do the job two or three times with no mistake and,then,
five or more times simply stop/during the washing/ for some reason like without supply in.Door lock is OK.
Any idea about this problem?December 14, 2006 at 9:10 pm #197922gegsy
ParticipantRe: Siemens Siwamat XB860
2 or 3 times in sucession?
If so it may be the pump jamming due to wear.
I cannot find that model on the system either, make sure its off the appliance door 🙂Greg
December 15, 2006 at 3:16 pm #197923gegsy
Thanks for PM, but can you please answer previous question re – 2 to 3 times in sucession? or 2 or 3 times with a break between washes.Regards
GregDecember 15, 2006 at 3:33 pm #197924Martin
Wow! I see a language problem coming on here?
Welsh to Serbo-Croatian, not an easy one?
I know Greg wants to put his finger on this one (painful though it is right now) and point you in the right direction at least?
December 15, 2006 at 3:36 pm #197925gegsy
Yea noticed the Serbian location. English seems good though, but quite welcome to have tech in German or Spanish aswell as English 😆
I have updated your post heading aswell Dragan to aid others to help you re- model number you PM’d 😉
GregDecember 15, 2006 at 7:10 pm #197926Dragan
ParticipantRe: Siemens Siwamat WXB860BY/05
Yes,few times in sucession.
Sorry if I make lot of mistakes in English.Dragan
December 15, 2006 at 7:26 pm #197927gegsy
Dragan its ok about your English.
I would guess and go for what I said about the pump. Have you removed filter and checked all hoses to pump for debris?Greg
December 17, 2006 at 3:37 pm #197928Dragan
Yes,it is completely clean.
Dragan
December 20, 2006 at 7:32 pm #197929S1MON
I had similar today found the pump was very worn and noisy with alot of play on the impellor.
December 21, 2006 at 8:19 am #197930Dragan
Thank you,Simone
