Siemens Slimline SF24A261GB/08
Problem with this Dw is the m/c is underfilling, i have replaced metering tank, pressure unit and cir pump, tank was completely blocked and impellor seal had leaked. The intitial fault appeared no pressure, cir pump running but no arm movement. I have had this before usually the impellor has come away from the motor.
On this dw it has the large heater matrix style side tank, which fill fine. The water will come in from the aquastop for around ten secs to fill the sump through the pressure bucket, but the water in the matrix is not released into the machine, so when the cir pump kicks in the virtually no water at all in the sump. I have checked both re-gen valves, there is 240v at the valves, I have removed and cleaned but it still does not want to release the water into the wash!
Any ideas?
