Siemens SMV65M00GB/14
  • #79881
    rocker
    just fitted a heater/pump to this D/W… when testing have a problem, set to heat cycle, it starts to take in a small amount of water in side tank and then stops ! tried on a rinse cycle it takes same amount of water to start with, but then circulating motor starts and water fills in tub and works ok, but the side tank dosent fill up to the top.. any help please.!!
    john
    #410934
    WhiteVanMan1
    Re: Siemens SMV65M00GB/14
    Impellor Jug?
    #410935
    nomadPaul
    Which side tank , left or right ? Not sure it actually fills on the initial start up or during cycles ready for the next fill ? The left hand side tank is the main tank with the right hand side tank only filling at final rinse I think.
