Re: Siemens SN26M890GB/07 fd 89
Martin, I must admit I wasn’t sure how to test the org heat pump, I metered the three pins across heater found circuit between two pins and o/c across three.
I assumed it was faulty, on testing new one it has same readings. !!
so now I assume a relays is faulty on pcb. no visual burns ect.
the customer has purchased a new d/w.
I have this one, hoping to send back the pump for refund, and refit the org one back and get emw to repair the pcb. to keep costs down
I may try and c/o relay from an scraped pcb. John
