Siemens SN26T297 dishwasher distributor
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens SN26T297 dishwasher distributor
  • #90526
    smeghead
    Hi all
    Anyone changed one of these for a late type Siemens dishwasher.
    Is it a base off job? 😕
    done loads of heat pumps, but not these distributor valves. ( 00644996 )
    Thanks.
    Clive
    #445097
    smeghead
    Re: Siemens SN26T297 dishwasher distributor
    Anybody ?
    Looks accessible when heat pump out of the way.
    #445098
    Houseproudtim
    Yes it’s same procedure as a heat pump, base off.
    Be careful with the o ring seal when fitting. I generally use a very small amount of washing up liquid to seat it correctly as they can kink up if you are not careful. Push on first then twist.
    #445099
    nomadPaul
    Houseproudtim wrote:Yes it’s same procedure as a heat pump, base off.
    You take the base off to change a heat pump?
    #445100
    smeghead
    No need to take base off for heat pump replacement.
    If that’s what you meant!
    I think there’s a locking tab which you press in then twist the distributor off, anyway I’ll find out on Tuesday next.
    Thanks anyway.
    #445101
    smeghead
    Sorry mate, you were right, 😡 Base off job – as the fan motor & container make it impossible to access the heat pump, you cant even lift the module out!
    Will know for next time though.
    Clive.
