Siemens SN63X00KG/04 (D/W)
  • #100171
    rocker
    Just some advice when press start button E19 flashes up…nothing happens…looking up fault code it could be a valve outlet…also possible the heat pump..On the bosh d/w they will run with no heat..just wondering if thats the same with a Siemens..if so it will point to the valve not the heater…can anyone confirm..please
    #479556
    check the valve coil and see if its open circuit
    rocker
    Hi Dave..it has a circuit
    #479558
    and the wiring back to the board, have you checked that ?
    rocker
    To be honest not yet..need to check in case of broken wire..will do
