Siemens SN65M031GB/03
  • #87422
    ChrisR
    Hi guys.
    Got one of these with a no heat fault.
    Replaced module and it seems to get warm but not hot.
    Are there any known faults on these or has anybody had a similar problem.
    Thanks.
    Re: Siemens SN65M031GB/03
    I have to ask, have you checked the heater element?
    #434805
    ChrisR
    yes it was ok. Earth testing was ok.
    It’s a strange one.
    The water appeared tepid(it’s a cold fill) but never hot.
    I’ve rechecked connections etc.
    Do you think the heater may be at fault?
    Thanks Martin
    #434806
    Did you change the module because of a no heat fault?
    What error codes came up?
    You should have readings of 10.5? and 21? across the heater terminals?
    10K? and 20K? across the Heat pump NTC at ambient.
    #434807
    ChrisR
    Yes module changed because of no heat fault.
    No fault codes and readings you supply are slightly
    higher than what I got
