Siemens SN65M031GB/14 Int’ Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens SN65M031GB/14 Int’ Dishwasher
  • #85300
    jontymox
    Good afternoon,
    I’m wondering if any help can be obtained with a problem on the above dishwasher?
    Essentially, nothing happens when any programme is selected.
    For example a programme is selected. (appropriate programme led flashes, as does time remaining display) start button pressed, and above lights remain lit.
    However, when the door is closed nothing happens… i.e. no drain, water drawn or wash action… the led’s remain lit, but nothing, including no error code/s!
    I initially removed the water in the system, and found some glass in the pump impellor, as I suspected the drain pump was faulty, as it was/isn’t draining.
    I’ve tried re-setting the programmes several times, and suspect the main electronic control module.
    I’m wondering if there is a test procedure for this dishwasher?
    Kind regards,
    jonty
    #428301
    Re: Siemens SN65M031GB/14 Int’ Dishwasher
    Door catch problem maybe? The machine may need adjusting (levelling) so that the door closes fully.
    #428302
    jontymox
    Thanks Martin,
    That makes sense… will update you later.
    jonty
    #428303
    jontymox
    Returned to confirm faulty sensor in interlock.
    Thanks again,
    jonty
