We have found a leak on the underside of the machine at the front right hand side. It seems to come through the cable cover where the cables run. The water drips into the bottom tray with some water tracking along the top of the tray. The machine is 5 years old and the door seals appear to be in reasonable condition with no real signs of deterioration. Any suggestions of the cause would be appreciated.
Thanks Dave, It is actually missing the plastic tray and dripping off the cable carrier at the bottom on the RHS. It drips on the floor in front of the tray and partly travels along the cables and drops into the tray. Just can’t tell where it is coming from. Don’t know if it is worth trying to replace the seals or just bite the bullet and replace.
