Re: Siemens sn66m054 gb/50 dishwasher
One side had snapped! So replaced the kit and found still leaking.
It’s quite a heavy long door so to fit it they have had to overhang the top of the outer decor door above control panel by 3 inches, so the door can swing under.
You then get a filler strip below the worktop which eventually swells with the heat this prevents door from closing properly.
I will quote them for panel! Thanks for the replies.
Steven
