Siemens SN66T091GB/21
  • #76256
    rocker
    Been to this dishwasher today,the drain pump is clicking when powered up but no movement. changed pump same fault, I presume the pcb is at fault. !! Can anyone confirm that a new pcb will resolve this issue, and will the drain pump also need replacing. thanks John
    #397808
    rocker
    Re: Siemens SN66T091GB/21
    can anyone please help. thanks John
    #397809
    rocker
    Trying again just in case someone may know !!
    #397810
    timdowning
    When you say powered up do you mean when the machine is first turned on? Or that there is power to pump. If power to pump then I would just change the pump and see how it goes.
