This siemens integrated slimline dishwasher will not fill. No mater what program you put it on all you get is the wash pump. The dishwasher is a slightly different lay out to the usual bosch/siemens set up. No flow meter/pressure switch, but within the fill chamber there appears to be a float and a reed(?) switch on the ouside of the chamber (opperated by a magnet on the float??). Is this switch the problem or any ideas??
This is an old bu&&er you got there. :rolls: The water block in the inlet/safety valve has probably activated and venting it may resolve the problem? However, the inlet matrix may have flooded to prevent that curing the problem so you may have to take the clear plastic tube (with the stopper on it) on the inlet matrix and drain off the flooded water first. 💡
