Siemens SR65T080GB/21 E.19
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens SR65T080GB/21 E.19
  • #101861
    FireFury
    My Siemens SR65T080GB/21 dishwasher is intermittently stopping with “E.19” on the display. According to Siemens/Bosch, this is either a faulty heat exchanger recirculation valve or a faulty detergent dispenser. I’ve replaced the valve, which has not fixed the problem, and cannot find a fault with the detergent dispenser. The error can appear during any part of the cycle, sometimes before even pressing “Start”, so I’m sure its nothing to do with the detergent dispenser.
    I’ve been unable to find a fault, so decided to take a gamble on a new motherboard. The only place I can find them is Aliexpress, so I ordered one and it arrived with all the right part numbers on the label. It appears to be electrically compatible with the dishwasher, but the programmes are wrong, the buttons map to completely the wrong functions and the blue light that shines on the floor to tell you its running doesn’t come on. My assumption is that lots of the Siemens/Boche machines use identical motherboards, but with different (or at least differently configured) software on them, and I’ve presumably been sent one with the wrong software on it. (?) There don’t appear to be any switches or anything on the board itself to configure it.
    The machine does run with the Aliexpress board (despite the buttons being mapped to the wrong functions), and is not coming up with E.19 any more, so that seems to confirm that either the original problem was with the motherboard, or that the new board works sufficiently differently that whatever the fault is doesn’t cause it to stop with an error. I’ve now been using the Aliexpress board for several weeks and it has stopped just once with an E.15 error (water protection system activated), so its possible that there is a leak somewhere, but I couldn’t see any water pooling anywhere.
    I have received a refund for the board, and ordered another from a different seller on Aliexpress (after checking with them that it is compatible), which turned out to be identical to the first one that I received, with exactly the same problem. I’m not sure where to go with this now – despite the Aliexpress board working, the buttons map to completely the wrong functions and the only programmes I can access are quite short and hot. I’m sure the programmes are not energy efficient, and they definitely don’t do such a good job of cleaning. Any advice would be welcome.
    Thanks.
    #486481
    FireFury
    I forgot to mention that the original motherboard has a label on it that says:
    9000 830 900
    melecs EWG AI 06.02
    18.09.14 03:54 D
    Typ: PC (220-240)V AC
    EPG70002
    Both of the new boards say:
    9000 830 900
    WKKT AI 06/02
    18.12.22 16:17 02
    Typ:PC (220-240)V AC
    EPG70002
    #486482
    its the software thats different. these boards are programmed for different machine but its the same basic board
    correct board is £200 thats the draw back
    you could ask QER if they can repair
    https://www.qualityelectronicrepairs.co.uk/
    https://www.siemens-home.bsh-group.com/uk/supportdetail/product/SR65T080GB/21#/Tabs=section-spareparts/Togglebox=tb0570/
    https://www.siemens-home.bsh-group.com/uk/shop-productlist/00755292
    #486483
    kaibart
    Think your not looking in the write area e19 is normally the drain valve heat exchanger valve faulty
    #486484
    FireFury
    kaibart wrote:Think your not looking in the write area e19 is normally the drain valve heat exchanger valve faulty
    Already replaced it.
    #486485
    kaibart
    Check the dispenser then as the fault relates to these 2 components
    #486486
    FireFury
    kaibart wrote:Check the dispenser then as the fault relates to these 2 components
    As I already said, I’ve already checked both of these components and there’s nothing wrong with them. Which is why I took a gamble on the motherboard.
