I have a Siemens SE26230GB/07 which stopped during the cycle and now won’t work. There was a small amount of dirty water under the door. Looking at the dishes inside I think it packed up during the rinse. It was off because it’s on a timer switch. When I turn the power on, the machine makes a very soft whirring noise and there is a flash of part of what looks like a 0 (zero) on the display. The whirring noise continues but nothing else seems to happen.
Thanks…we cleared the pump area but there’s still a low humming noise and a quick flash of the zero when you turn the machine on. I wasn’t quite sure what you meant by resetting …is that where you press two of the programme keys at the same time…if so which ones?
