Siemens sx65E001gb/1.7 flashing tap icon
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens sx65E001gb/1.7 flashing tap icon
  • #95556
    Andrew Rayner
    Hello I have just moved into a house with above integrated dishwasher.
    The tap icon is flashing. Unfortunately due to age it has no screen. I have checked the pipes and they are not bent. I have checked filter and its clear.
    It appears to be constantly draining. What is the fault?
    Is it economically repairable?
    #460735
    so from what your saying the pump runs constantly no matter what you do
    if yes
    take the cover off the base under the door (after taking the plug off) and see if there is water in there. There is a float in the base that detects leaks. if water is in there is stops the programme and starts the pump until the water has gone or its switched off
