Hi, Just fitted a new pump motor to our Siemens Extraklasse T1200A top load washing machine but now it wont run and gives a fault code of 83. Can anyone advise what the fault codes are on this machine. Ive checked all the wiring connections and all seem ok. The pump had blocked which had burnt the old motor out, could this have affected other circuitry?
The E-Nr. is WP91281GB/05, FD 800100099.
Tim
Assuming the pump is good and the wiring is as it should be then….
I cant help you with the fault codes but I have seen control board damage
as a result of a burnt out motor.
Check the pcb and the tracks that go to the pump connector and see if there
is any sign of damage.
If you are handy with a soldering iron you may be lucky.
