Siemens T1200A Help
  • #7050
    Lawrence emailed me with this request earlier, can anyone help?
    Hi Ken,
    I am trying to identify this part for a part number.
    I have the diagram faxed to me from BHS but still cannot see it. I wonder if any one might be able to tell me if it comes as part of something else.
    This is the button that protrudes through the control panel and it is pressed to open the lid.
    This part is mounted behind the bezel and is not part of the lid latch group situated under the inner tub area top front. When pressed it engages with that group to activate the lid being opened.
    Any help would be appreciated.
    Siemans T1200A ENr WP91281GB/05
    Many thanks
    Laurence
    The pics are…
    Cheers
    superfix
    Re: Siemens T1200A Help
    If it is part of the bank of 5 buttons then it’s part no 168320.
    If part of the bank of 3 then it’s part no 168318.
    Alternatively order complete facia part no.356778.
    Hope this helps.
    #121173
    laurenceuk
    Thanks Boro,
    It is the middle of the bank of 3 buttons. On the drawing it is part No 1683191. But is this the button only or the fixture it is engaged in (see photo) also. The fixture itself pivots on 2 lugs inside the black casing part No 351466 and the other end is attached to a spring clip to cause it to reset the button.
    Clear as mud eh!
    Laurence
    #121174
    It’s the panel complete – 356778 – list is £64.27 :eeek: .
    Got caught with the Bosch version (WOK2001) a while back; customer was not a happy bunny!
    laurenceuk
    Thanks Penguin,
    Much appreciated.
    Laurence
    #121176
    boro wrote:If part of the bank of 3 then it’s part no 168318.
    Laurence,
    From the photograph you sent it looks as though it’s just that button thats cracked, in which case all you need is 168318 as boro mentioned (all of £1.29) 😉
    laurenceuk
    Thanks Martin,
    The button is detachable from the cradle which is the part that is snapped in half. Apparently the part No that you and Boro gave is for the button only. I was able to get through to BSH technical this morning and he says that part is a fixture of the facia panel 🙁 at £59.33 inc vat and p&p, trade.
    I will let you know the outcome should the customer want it done.
    But thanks all for your input, it is very much appreciated.
    Laurence
