Siemens TD WT34V397GB/02 No Heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens TD WT34V397GB/02 No Heat
  • #91305
    subs
    FD8708
    This vented dryer is not heating. The heater looks and tests ok. It even warms very slightly but doesn’t get hot. Am thinking the ntc is playing up. Getting around 10,000 ohms through it. I see the sensor is available separate or comes complete with heater and cut-out stats. Anyone familiar with this problem?
    Subs
    #447698
    kaibart
    Re: Siemens TD WT34V397GB/02 No Heat
    I know it’s a silly thing to ask but the vent hose has a straight run of 400mm before a bend? Have you checked the front sensor?
    #447699
    subs
    Hi, if you mean the one that’s like a pin by the front filter then I did. It was covered in fluff which I cleaned completely.
    Subs
    #447700
    subs
    Anyone had a thermistor in the heater give wrong reading making the heater do no more than warm up?
    Subs
    #447701
    kaibart
    If you want to be on safe side change the front and back sensors I know the 1 on the heater does give trouble from time to time
