Siemens Top Line Washer/Dryer – not heating water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens Top Line Washer/Dryer – not heating water
  • #7716
    Hello all,
    I have ordered a new heating element for my Siemens TopLine washing machine and I am seeking any advice on fitting it – I assume it is reasonably easy (if you’ve done it before)?
    I know the safe answer is to get a qualified service engineer, I’m just checking all the options before going down that route. If everyone says call an engineer, I’ll take the advice!
    Sam
    #124793
    Re: Siemens Top Line Washer/Dryer – not heating water
    Sam,
    Full model and FD number would help us help you please?
    Sorry:
    Siemens Top Line
    E-NR: WK61420GB/13
    FD 770900004
    Sam
    #124795
    Sam,
    It is not a difficult job changing the heating element for someone with a decent set of tools and the knowledge of how to use them. The Heater (Part No: 263726 cost £29.73) available from: –
    http://www.bshappliancecare.com/bshspares.html
    But firstly, and before taking that route, may I just ask, what are the symptoms that make you conclude the heater is faulty anyway ❓
    Symptoms: normal operation through the wash cycle EXCEPT hot water.
    Sam
    #124797
    Sam,
    Then I have good news….IT IS NOT THE HEATER AT ALL :tup:
    Your machine would not (I repeat WOULD NOT) complete a full wash/rinse/spin cycle if the element were at fault. In fact it would sit on the wash cycle for FOR EVER!!
    Now say on a 40 degree wash cycle, you would hardly detect the heater warming up the water inside, because there is very little water in there to notice. :con:
    So what makes you think the heater is faulty, is it not washing properly, are the clothes coming out well spun???
    Do tell me more, so I can figure your problem out (by remote control as it were) 😀
    That makes sense. I’m going to try a hot white wash now – I should be able to detect that (90 deg)?
    Then if you’re right I’ll need to cancel my order from BSH!
    I’ll let you know the result.
    Thanks,
    Sam
    #124799
    OK, so I can notice heating on the 90 degree wash, it was a mis-diagnosis. 😳
    At least I was smart enough to get some advice,
    Sam
    PS. Does anyone need an unused 263726 heater element?
    #124800
    SamInClerkenwell wrote:PS. Does anyone need an unused 263726 heater element?
    :rotl:
    P.S Keep it, you never know, it may come in useful 😀
