siemens vario electronic fault
Home Forums Public Support Forums International Forums European Appliance Forum siemens vario electronic fault
  • #38268
    Marita
    Hi Greg,
    I was reading your communication with Jan M., as I have the same problem with my Siemens VARIO electronic Fridge/Freezer,
    approximately 8 years old.
    It has developed the following fault. On switching on both freezer/fridge run normally up to cold temperature set.
    On reaching this set temperature the motor switches off as you would expect. But the motor fail to restart as the temperature rises.
    By switching the freezer off then on it will repeat the above cycle, but only after trying several times before the motor starts again.
    Any ideas what the problem is and how to fix it?
    My cerial number:
    DA 11OE13RBY5(89237)
    SXH 3041986
    Thanks a lot for your help,
    Marita
    #258297
    gegsy
    Re: siemens vario electronic fault
    If you can pop the full model number up just to refresh my memory 😀
    Its sounds as if the foamed in NTC has gone out of tolerance and in need of a bypass kit.
    Will know more when you relpy 😉
