Siemens VARIO electronic Fridge/Freezer– Help Please
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Siemens VARIO electronic Fridge/Freezer– Help Please
  • #8281
    Glenn
    Hello
    Last week . I had not put the right model information in my email 😳 this has now been added below.
    Thank you for your time in reading this again.
    Glenn Gibbs
    I have a Siemens VARIO electronic Fridge/Freezer
    Approximately 3/4 years old,
    It has developed the following fault. On switching on both freezer/fridge run normally up to cold temperature set.
    On reaching this set temperature the motor switches off as you would expect. But the motor fail to restart as the temperature rises.
    By switching the freezer off then on it will repeat the above cycle
    Any ideas as to if this is a thermostat problem or circuit-board problem?
    availability of a replacement item or items if so what approx cost.
    I live in the Manchester area
    The following serial numbers
    E-NRK931V04GB/06
    FD.7903/02256
    #127805
    Simon46
    Re: Siemens VARIO electronic Fridge/Freezer– Help Please
    It may possibly require a modification to it. And no parts required! best to get an engineer to it. Click on red toolbox to find one in your area.
    Regards
    Simon
    #127806
    Glenn
    Hi Simon
    Cant see or find Red toolbox?
    Glenn
    #127807
    Glenn
    Go to repairs@ukwhitegoods.com
    The fridge evaporator sensor has failed.It needs a by-pass :mrgreen:
    #127809
    Simon46
    What is your postcode?
    #127810
    Glenn
    My Postcode is BL8 2JZ
    Regards
    Glenn
    #127811
    Simon46
    Glenn check your private messages box on the home page.
    Regards
    Simon
