Siemens vented dryer.
  • #101713
    SWERV
    another company had been out to this dryer and had ordered a belt for it as it had snapped.
    The customer contacted me after a couple of weeks because the other company said the belt was out of stock and they didn’t know how long it would be. I went armed with a belt and sure enough the old belt was tucked inside the machine and it had snapped. After fitting the new belt and then testing it, the dryer runs for a couple of minutes on timed dry and then shows error F09.
    The thermal cut outs are all ok, as is the NTC and the heater circuits measure 110 ohms and 40 ohms. Does anyone have any ideas as to the cause of fault?
    The Enr is WT34V397GB/01
    Merv
    #485757
    kaibart
    This is info on f09 Hope this helps
