Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › siemens w/dryer.wk61420gb/13
- This topic has 8 replies, 3 voices, and was last updated 16 years, 8 months ago by
adv.
August 5, 2009 at 10:43 pm #47615
adv
Participantshut door starts fill thens stopts after 30 secs an can open door here clickin noise ie like a relay am thinkin door lock or maybe carbons? help guise 😆 also wont spin drains tho
August 6, 2009 at 8:18 am #294016adv
ParticipantRe: siemens w/dryer.wk61420gb/13
any 1 😆
August 6, 2009 at 10:15 am #294017Martin
I’m not sure on this one? It could be motor brushes but I guess you’ll need to check? Also the usual, valve, heater and most important, the air pressure chamber of course. 😉
August 7, 2009 at 1:59 pm #294018adv
fitted door interlock to this. door locks properly now but. fills up for bowt 20 secs then justs stops. doesnt adjutate.when put on spin it drains no motor action / then after 20 secc pump stops and just does nowt? help, will need back half if brushes. some one mensioned pressure chamb 😆 er. wat goes wrong with that?
August 7, 2009 at 2:32 pm #294019Martin
adv wrote:will need back half if brushes. some one mensioned pressure chamb 😆 er. wat goes wrong with that?
If brushes? 😕
What are they like anyway?…Have you checked for continuity through the motor?
‘Twas I that mentioned pressure chamber and they do get crudded up and can affect the pressure switch (empty/full) settings. 😯 . So a quick 5 second ‘flick it off and check it’ is worth hours of headscratching I shouldn’t wonder. 🙂
My gut feeling instinctively goes to the motor as the main suspect though I suggest a close look there worth your while. Although please don’t invest in a rear motor end frame on my say so only to find that’s not the problem…OK?
Try the Penguin45 method if the brushes are worn and you don’t want to burn your fingers over costings by just sticking pattern carbons in. 💡
Good luck and may the force be with you! 8)
August 7, 2009 at 3:32 pm #294020adv
its intigrated an mare to get out just was lookin for a few opions before a take kitchen apart . cant change carbons on this model they come with back haif.at least a think u cant.ther not the type with tab and spring 😳 😈
August 7, 2009 at 6:21 pm #294021Madmac
adv wrote:its intigrated an mare to get out just was lookin for a few opions before a take kitchen apart . cant change carbons on this model they come with back haif.at least a think u cant.ther not the type with tab and spring 😳 😈
Ahh, but if youre willing to get down & dirty with a pair of pattern Bosch brushes & a soldering iron, its suprising how you can beat the system.. if however it explodes, showering your punter in commutator segments… you aint seen me.. right? 😉
August 8, 2009 at 10:49 am #294022adv
August 17, 2009 at 3:33 pm #294023adv
was carbons on this :rolls:
