siemens w/m lights on but no go
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemens w/m lights on but no go
  • #38136
    bzz67
    WIQ1430EU/01
    SIEMENS comes up in large blue display when mains is on, apart from the odd flicker, nothing else will work. had a look around all three pcb’s etc but can’t see anything obvious. not worked on many of these so any help would be great.
    thanks
    #257828
    gegsy
    Re: siemens w/m lights on but no go
    If its doing that it relates to the analogue sensor being out of its operating range or connection from it to the module missing.
    If required its 182238 £23.69 + the usual.
    As if you didn’t know, they don’t click when you blow down them. Usually doing this results in permanent damage to the little guy 😀
    bzz67
    thanks, i’ll give it a go.
    ps: of course i knew not to blow into it 😉 😳
