Siemens warming draw BI630CNS1B/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens warming draw BI630CNS1B/02
  • #99553
    dunston
    Fault is the light is flashing. We replaced the coupling 00612218.
    The light is still flashing. Tested the circuit in the glass draw connected to the coupling and its open circuit.
    Anyone got a circuit diagram? Is the circuit in the glass draw a heater?
    #476860
    suedehead1
    its the element Siemens call it a BOWL if when the drawer is closed if it doesnt get a circuit through it it thinks the drawer is open and flashes the
    light I have fixed about 6 the same. its a costly item though but easy to change
    #476861
    dunston
    Thanks for the reply. Yes the parts are expensive. Wanted to make sure no other fault.
    #476862
    dunston
    Our customer wants her warming draw repaired. Where did you order the part from? Its a special order from Connect
    #476863
    suedehead1
    I got one from qualtex but you might get it direct from Siemens
