siemens washer
  • #84278
    cornflakes
    model WIQ1834GB/01
    FD 8501
    called to this appliance,, builders have moved machine when stripping out old kitchen to new part of house
    unit switches on
    panel lights up
    you can select a programme
    as there was no water connection I programmed drain or spin cycle
    1] start light flashes…a single bleep but no action
    no error code showing
    thanks for any help
    graham
    #425259
    nomadPaul
    Re: siemens washer
    Try starting it with the door open and see if you get the same symptons. If you do,Check the door lock and especially the door wiring loom adjacent to the lock itself. Seen quite a few where the wires get chafed and break on the casing.
